bigger tires
Old Jan 30, 2008 | 02:15 AM
jarebear86's Avatar
jarebear86
Default bigger tires
i went from the sticker on the door of 225 size tires to 305 tires. do i really need to change my gears and what will happen if i do change them and what till happen if i dont?
Old Jan 30, 2008 | 02:38 AM
Mudbone25's Avatar
Mudbone25
Default RE: bigger tires
Its more preference and what you use the truck for that judges if you should do gears or not. If your not doing much highway driving you may find that its not worth the money. As far as i know you wont be doing any damage running the bigger tires. The bigger tires will more likely effect wheel bearings, tie rod ends and track bar.
Old Jan 30, 2008 | 02:47 AM
rabbler's Avatar
rabbler
do you need to change them ? No
But you will probably find your truck seem a bit low on power now and your fuel economy will probably take a hit
Old Jan 30, 2008 | 02:50 AM
jarebear86's Avatar
jarebear86
well i live in the city so i do do a good amount of high way driving so do u think that i should get them changed?
Old Jan 30, 2008 | 02:58 AM
Mudbone25's Avatar
Mudbone25
Depends on what kind of money you want to spend on the truck. Gears are gona be around 1000 bucks an axle from what ive found around me. It might make more sence to spend money on some cheaper proformance mods. Intake, throttle body, exhaust can help bring back some of the power lost from the bigger tires.
Old Jan 30, 2008 | 03:01 AM
jarebear86's Avatar
jarebear86
i dont really wanna speand alot of money at all. i already ordered a CAI and ive heard good and bad things where would i get a better throttle body?? and i have a flow master 40 series muffle with an exhaust cut out also. but what do u suggest is the best thing to do more the best gain of hp and acceleration???????
Old Jan 30, 2008 | 01:09 PM
zique's Avatar
zique
Since you have a 2wd you will only have one axle to do...you can expect to pay about $500-800 for a good set of gears and the install. I would suggest it considering the increased tire. If you don't change them with that large of an increase, you are placing more stress on your drivetrain components, and we all know how strong these Dodge transmissions are.
