P1281 Help
Old Jan 30, 2008 | 06:15 PM
2 Marks's Avatar
2 Marks
Default P1281 Help
Just got this code today. Any help would be appreciated.
Old Jan 30, 2008 | 06:38 PM
2 Marks's Avatar
2 Marks
Default RE: P1281 Help
OK figured it out. It is engine too cold too long. Anyone know of a place to get engine bras so I don't have to swap out the 180 stat in the winter?
Old Jan 30, 2008 | 06:45 PM
aim4squirrels's Avatar
aim4squirrels
Cut a pizza box and put part of the cardboard in front of the radiator. I suggest the cooler return side. You can buy fancy ones if you want, try LMC or Geno's garage.
Old Jan 30, 2008 | 06:52 PM
2 Marks's Avatar
2 Marks
thanks.
Old Jan 31, 2008 | 01:07 AM
dhvaughan's Avatar
dhvaughan
my engine was recently taking longer and longer to warm up and giving me less and less heat. it finally threw a 1281 and took 10 miles to put out any heat at all, wouldn't get above the 160 range no matter what. bought new t-stat and tested the old and new in a pot of water on the stove. the old one was cracking open at about 160-170, combined with the drilled hole = not much heat.
i've rethought this drilled hole idea from a winter perspective. its a stupid idea.
