need help
Old Feb 2, 2008 | 04:33 PM
kenneth1011's Avatar
kenneth1011
Default need help
1994 dodge ram pickup gas, started fine noticed gas was run low in tank put gas in at gas station .sputtered a second when started then died would just crank after that.think run it out of gas.where should i start to get it running again
Old Feb 2, 2008 | 04:49 PM
TheForce55555's Avatar
TheForce55555
Default RE: need help
Turn the key to the on position and try to hear if the fuel pump is working. If it is turn, the key off and on a few times and that should get fuel up to the motor and make it run. If not, you might have to bleed the fuel system some trucks have a schrader valve on the fuel rail, It looks like a Tire valve
Turn the key on and press the stem down in he middle of the valve, make sure to put a rag over it, so you dont get sprayed in the face with fuel,Its something like 43psi in the fuel rail
If you dont have the tire valve on the fuel rail, like me. I would just disconnect the fuel line on the engine and turn the key on and see what happens
