abs light and parking brake lights on
Old Feb 3, 2008 | 01:37 PM
deancain87's Avatar
deancain87
Default abs light and parking brake lights on
my old man has a 2001 ram 1500 5.9 and a while ago his abs light and parking brake lights came on i put new brakes on the front but that didnt help so then it must be the back or theres a fault somewhere, but i just havent had a chance to change'em
Old Feb 3, 2008 | 08:18 PM
408Ram's Avatar
408Ram
Default RE: abs light and parking brake lights on
It would be a good idea to check the rear but that should not cause the lights to come on unless the break fluid is low. You will have to hook up to a scan tool and read the codes. Most of the time it is a speed sensor.
Old Feb 3, 2008 | 09:08 PM
Parts/Service's Avatar
Parts/Service
This is uslauuy caused by the speed sensor on the top of the rear differential. But it could be wiring or a ABS sensor on the front wheels....
