rear turn signal question...
Old Feb 4, 2008 | 08:19 PM
brian547's Avatar
brian547
Default rear turn signal question...
just got an 00 ram, trying to fix little things so i can get it inspected. replaced the rear turn signal light. it worked then went out like 5 minutes later. put another new bulb in and still doesnt work. im not to good with electrical issues so any input would be appreciated...
Old Feb 4, 2008 | 10:25 PM
dhvaughan's Avatar
dhvaughan
Default RE: rear turn signal question...
sounds like you might have blown a fuse ? check fuses in the end of dash, drivers side.
Old Feb 4, 2008 | 10:46 PM
jasonw's Avatar
jasonw
Site Moderator
+1 for checking the fuse.
By "doesn't work", do you mean the new bulb lights up but doesn't flash, or it doesn't light up at all?
Old Feb 5, 2008 | 06:58 PM
brian547's Avatar
brian547
yea, the first thing i did when i saw it wasnt working was check the fuses. there good, and i figured they are all on the same circuit so they would all be out. and i meant thatit doesnt work at all as in no light. also, does anyone have a part number to the license plate light housing. the light is there and works but the grommet/housing isnt in the exit hole. .....thanks for the help so far...
