first time tow, how to prep?
Old Feb 6, 2008 | 01:02 PM
8t5gt's Avatar
8t5gt
Default first time tow, how to prep?
hey guys, this will be my first time towing a trailer with the ram. im just wondering what i should do to prep it, its got a ton miles on it as u can see in my sig. i know i will get a tranny cooler, any suggestions on that?. i just did a really good rad flush and it has a new rad it in. i cant think of stuff i need to prep in order to tow. any suggestions would be awsome. thanks guys!
Old Feb 6, 2008 | 01:21 PM
hometheaterman's Avatar
hometheaterman
Default RE: first time tow, how to prep?
Tranny cooler. Turn overdrive off when towing. Thats all I can really thing of off the top of my head. I've heard a few people say that they put premium in when they tow with it.
How much are you planning on towing here?
Old Feb 6, 2008 | 02:32 PM
xskylinedx's Avatar
xskylinedx
Depending on trailer wieght it probably wouldn't hurt to just check your brakes and make sure they don't need servicing.
Old Feb 6, 2008 | 04:10 PM
TheForce55555's Avatar
TheForce55555
+1 on the brakes, if you cant stop, no sense in tryin to tow
Also check all the fluids, and top off as needed
Maybe even due a tranny service to make sure its up to par
Old Feb 6, 2008 | 06:20 PM
8t5gt's Avatar
8t5gt
oh sorry, im towing a mustang to the track. ok thats all i could think of was the cooler. even on the higway leave od off? the rpms get pretty high round 130-160 ( kms/h) i just did front brakes, i need to bleed them tho they seem a lil spongey.
Old Feb 6, 2008 | 06:33 PM
hometheaterman
I'd get a brake controller as most likely a trailer that big will have brakes on it. I'd for sure leave OD off even on the highway with something as heavy as a car and a trailer big enough to hold it.
Old Feb 6, 2008 | 09:19 PM
aim4squirrels's Avatar
aim4squirrels
What kind of hitch/trailer setup you got? If you've got an anti-sway bar and load equalizers you'll be much happier. First time I towed, my Dad made me run a 24' travel trailer down the highway with and without those just so I'd be grateful. I was
Old Feb 8, 2008 | 10:01 PM
towguy2007's Avatar
towguy2007
8t5 i tow my camaro to the track with my 1500 i always shut od off and i also add a second tranny cooler for add saftey always do a pretrip inspect make sure all your tires are up to pressure fluids and any thing else you can think of at the time like before i go i make sure everthing is lubed and full i may even drop 5 to 10 lbs of air out of the tires for more traction mileage goes done but you cant be the traction you get from it
