QUESTION ABOUT FUEL CELLS
Old Feb 6, 2008 | 07:07 PM
towguy2007's Avatar
towguy2007
Default QUESTION ABOUT FUEL CELLS
DOES ANY BODY HAVE OR THOUGHT ABOUT PUTTING A AUXILARY TANK IN THERE TRUCK AND IF YOU HAVE ONEHOW EASY WAS IT TO PUT IN CAUSE I AM THINKING OF PUT A 55 GALLON RESERVE TANK IN THE BED OF MY TRUCK ANY THOUGHTS WOULD BE GREATFUL
Old Feb 6, 2008 | 08:46 PM
zddp8868's Avatar
zddp8868
Default RE: QUESTION ABOUT FUEL CELLS
can you plumb fuel line and run electrical wires? im assuming you want to hook up a fuel gauge to this auxilary tank? if so, you will needanother fuel gauge sending unit. you also have to ask yourself: do you want to have 2 fuel gauges or just one that is controlled by a switch? keep in mind your fuel economy will decrease because that tank filled will weigh 357.5 pounds plus the weight of the tank...
Old Feb 8, 2008 | 09:46 PM
towguy2007's Avatar
towguy2007
whats an extra 360 lb i pul a 30 ft trailer with my 1500 with a car on it so weight isnt an issue
Old Feb 9, 2008 | 01:41 AM
zddp8868's Avatar
zddp8868
ORIGINAL: towguy2007
just makin sure you understand all of the good and bad of this operation.
first step:
get the tank and mount it.
