Pipe Size
Old Feb 8, 2008 | 09:30 PM
zddp8868's Avatar
zddp8868
Default RE: Pipe Size
PIPE DIAMETER DOES AFFECT SOUND.
that said, go with a dual setup with an H pipe. 2.5 inch pipes. the most power you're going to see out of the truck, with a great rumbly sound.
you pick your muffler. im not giving advice on mufflers, thats up to the user.
Old Feb 8, 2008 | 09:31 PM
zddp8868's Avatar
zddp8868
or you could go with this O pipe:
http://kalecoauto.com/index.php?main...d=2&page=2
its the best exhaust setup ever created.
Old Feb 8, 2008 | 09:43 PM
RamGuy318's Avatar
RamGuy318
H pipe would require me buying 2 new cats, 2 new mufflers.....thats a little too much for me. I could be wrong but, i believe that is out of my price range.
Old Feb 8, 2008 | 09:55 PM
zddp8868's Avatar
zddp8868
ORIGINAL: RamGuy318
put ONE cat in your crossover pipe. (in the middle part of the H itself)
2 mufflers, yes, but its worth it. do it perfect once and FORGET IT.
Old Feb 8, 2008 | 10:04 PM
zddp8868's Avatar
zddp8868
its actually not that expensive either. if you do it yourself, it only costs you the price of parts, which wouldnt be more than 250 bucks. any reasonable exhaust place will do this custom exhaust work for around 500-600 total.
Old Feb 8, 2008 | 10:13 PM
RamGuy318's Avatar
RamGuy318
So wait.. since my cat is a si/so.. wont that be a problem? could i see some pictures?
Old Feb 8, 2008 | 10:27 PM
zddp8868's Avatar
zddp8868
ORIGINAL: RamGuy318
let me geta picture for ya.
if your cat is 2.5 inches on both the inlet and outlet, then you should be fine, sir. give me a few minutes to upload a picture or two. ill draw you a diagram too.
Old Feb 8, 2008 | 10:36 PM
zddp8868's Avatar
zddp8868
[img=http://img178.imageshack.us/img178/753/exhaustsetupei2.th.png]
theres the idea for you. the picture i have has no cat, and its an x pipe.
this exhaust setup will sound and perform great.
Old Feb 8, 2008 | 10:56 PM
RamGuy318's Avatar
RamGuy318
Ok im going to go with an H pipe 2 cats, 2 mufflers.. flow 40's. Now, what do i have to buy? Can i buy a kit? Help please.
Old Feb 8, 2008 | 11:02 PM
Slomojo01's Avatar
Slomojo01
i THINK GETTING A LOUDSPEAKER AND PUTTING THAT TO THE TAILPIPE WILL PRODUCE THE BEST RESULTS WHEN IT COMES TO MAKING THE TRUCK SOUND BETTER WHEN LOUD IS YOUR GOAL.
