lifted 4x2 need help with measurements
Old Feb 9, 2008 | 04:02 AM
proshine43's Avatar
proshine43
Default lifted 4x2 need help with measurements
hey guys, i need your help. i have a lifted 98 1500, the front tires are angled like so / \. the upper control arms are set out as far as they will go. alignment shop did the best they could. i need the length of your upper control arms to see if i have the right ones. i dont want to buy new ones if they're the same size as everyone else. i'm on my second set of tires. thanks.
Old Feb 9, 2008 | 05:01 AM
Slomojo01's Avatar
Slomojo01
Default RE: lifted 4x2 need help with measurements
I could easily be wrong, but could it be your coil springs not being long enough that caused your camber to be off like your explaining?
What ind of a lift does the truck have? please be specific.
Old Feb 9, 2008 | 05:51 AM
01Tx1500's Avatar
01Tx1500
Like Slomojo01 said, we need more details on the lift and what all it came with. Plus, have you checked the upper ball joints? Probably not the problem but worth a check. My Chevy was doing the same thing once, replaced both upper balljoints and now they dont lean at all.
