New truck it WAS HOT look at the pics
ORIGINAL: mr freeze
Valve adjustment?
Valve adjustment?
So are you parting it out after grabbing what you need or what?
Hows the engine wireing harness look, seeing how the 95/96 arent interchangable?
there is an injector wires plastic melted thats it and the cover thing that holds all the wires in is melted a little tape will fix it though
is just the inside the cab wires are melted
so i hope that the cab wires from the 95 will clip right on if not ill cut then and make it work
pretty sure im gonna try to fix it but it needs to get warmer first its like 4 dergees with the wind chill and i dont have a heated shop
