spark plugs
Old Feb 15, 2008 | 11:12 PM
padodgeram's Avatar
padodgeram
Default spark plugs
Any one using the accel u groves ?? , My autolite 3923 are giving me issues (light throttle stumble).... If no one has i guess ill be the ginnie pig..
Old Feb 15, 2008 | 11:47 PM
Ram2K1's Avatar
Ram2K1
Default RE: spark plugs
ORIGINAL: padodgeram
Oh f*ck, don't tell me that...I just put 3923's in... Jr. Mechanic, I'm gonna come and smack you Seriously though, I don't know... I almost bought that Accel tune up kit from Summit...it had those plugs in it... I would think they are probably good plugs...they make good wires. Be the guinea pig for us[8D]
Old Feb 15, 2008 | 11:54 PM
padodgeram's Avatar
padodgeram
i wouldnt worry to much with your set up using the 3923.. this only happen tonite and only 2 times on very light throttle then i hammered it a few times and no stumble but my plugs look like there fouled , with my 3924s had that nice tan burn...
Old Feb 15, 2008 | 11:56 PM
Ram2K1's Avatar
Ram2K1
Hey sorry to go off topic, but what was that p/n for the msd oem replacement coil?
Old Feb 16, 2008 | 12:02 AM
padodgeram's Avatar
padodgeram
lol...np ... 8228 factory replacement. but you gotta use the accel harness ACCEL 140021AH
Old Feb 16, 2008 | 12:10 AM
Ram2K1's Avatar
Ram2K1
gracias (sp?)
Old Feb 16, 2008 | 12:21 AM
rabbler's Avatar
rabbler
3923 Heat range might be a bit to low for winter.
Do you make a lot of short trips? That could lead to fouling.
It is quite a bit cooler than the stock ones
I ran Denso U-grooves in my Honda CBR 1000 with no issues.
I don't think there is really much performance to be gained in difference in spark plug design.
Really only one way to know for sure though [sm=smiley20.gif]
Old Feb 16, 2008 | 12:31 AM
padodgeram's Avatar
padodgeram
i dont drive the truck to much, so that could be why i have the issue , tomorrow ill put my hotter coil on and see what happens worse comes to worse ill try the accel plugs.. right now my gap is set at .045 , with the 3924s i had em set at .050 .. back to the drawing board , plus i added the mopar PCM , got the bugs worked out of that and she screams , and if what silver said about the B&G ill **** myself , or a SCT tuner..
Old Feb 16, 2008 | 12:39 AM
rabbler's Avatar
rabbler
.050 with the MSD? Man thats got to be toughon the cap and rotor! Nice set up though
Old Feb 16, 2008 | 12:44 AM
Ram2K1's Avatar
Ram2K1
Okay, so the factory gap is .040, which is where I have my 3923's set right now. I'm going to get that MSD coil (8228), so will I need to change the gap on my plugs? I will be running the Jeg's 8mm wires, Jeg's dist cap & rotor, and the MSD coil with the 3923's.
