Air Cleaner Gasket
Old Feb 19, 2008 | 05:15 PM
wvjefo's Avatar
wvjefo
Default RE: Air Cleaner Gasket
If you have the Edelbrook you can do the breather hose easy.
The filter comes with a piece that works with a 3/4 hose.The filter housing has two spots for mounting. I did mine so it's on the front drivers side. Use 1/4 drill bit to mount.
The breather hose is 1/2 so you need an adapter.
TA DA you be legal.
Jeff
Old Feb 19, 2008 | 08:13 PM
RUgbykid69's Avatar
RUgbykid69
well i jsut bought a self breather instead of using that hose..and if hit the throttle body linkage are you sure you had the two indents on the bottom part of the air filter in the right spot..if you have them facing the quater panels u should be fine i figure..but im buying a 1/2" mr gasket air filter riser from autozone(say itll be a few days to get it in so i figure ill deal with the noise for now)... im not sure if thats the same thing you guys are talking about or not
Old Feb 19, 2008 | 08:27 PM
1BigRamaniac's Avatar
1BigRamaniac
RU: I am running a stock set up right now. I remember that 'gasket' thing. It broke and I pitched it years ago. You probably do not need it, unless you are just one of those guys that worries about the air in his tires getting old or something.
If you are going round, the breather filter looks cool.
wvjefo: you know we would like to see some pictures of that! Welcome to the forum!
