97 ram 1500 electrical problem... any help?
Old Feb 18, 2008 | 07:37 PM
dunca122's Avatar
dunca122
Default 97 ram 1500 electrical problem... any help?
Just yesterday my lights turn on now everytime i touch the brakes and my left blinker won't blink anyone got any ideas what it could be?
Old Feb 18, 2008 | 07:59 PM
TheForce55555's Avatar
TheForce55555
Default RE: 97 ram 1500 electrical problem... any help?
its probably a bad ground at the tailights, check them to make sure they are connected and clean them with a wire brush to get a good ground
Old Feb 19, 2008 | 05:00 PM
dunca122's Avatar
dunca122
where abouts by the tail lights are the grounds located?
Old Feb 19, 2008 | 09:23 PM
jasonw's Avatar
jasonw
Site Moderator
I'm not sure about the lights/brake issue, but if the left blinker doesn't blink, it might just mean a tailight or front signal bulb is burned out.
Old Feb 19, 2008 | 09:30 PM
bozzoswald's Avatar
bozzoswald
check the bulb connection first. if you have aftermarket trailer harness see if someone butchered the harness-scotch lock or butt connectors-need to be soldered and heat shrunk
