make it look mean!!!!
Old Feb 21, 2008 | 01:39 AM
  #21
my1500.net's Avatar
my1500.net
Default RE: make it look mean!!!!
I will post some actual pics as soon as the newfront bumper is painted, winch is installed & all put back together. Without the make believe minigun;-)
Old Feb 21, 2008 | 05:36 AM
  #22
v10power's Avatar
v10power
LMC has some pretty cool and 'mean' looking parts and accosories for these trucks. I never ordered anything from them but i want too, anyone have any experience from them either good or bad?
Old Feb 21, 2008 | 08:11 AM
  #23
WD OPN Throttle's Avatar
WD OPN Throttle
You could try 4WD...
Old Feb 21, 2008 | 08:15 AM
  #24
WD OPN Throttle
LMC is pretty good. I have yet to try to order a part that is not in stock. Just double check your part numbers when you order, and have them check th enumbers on their end.
Old Feb 21, 2008 | 07:40 PM
  #25
mopar crazy's Avatar
mopar crazy
Ya know, I was just thinking about this topic the last week after I watched Mad Max 2 - The Road Warrior. Some things I came up with were....
1. ya would have to paint the truck flat black or a flat primer black.
2. get a simple looking brush guard in flat black. maybe add some off-road lights to it.
3. if your truck has no tonneau cover, add a flat black roll bar to the bed with off-road lights on top. if truck has a tonneau cover on it then add a roof mounted light bar.
4. definitely get some flat black rims that are a little offset to give the truck a nice stance.... with off-raod tires of course.
5. bust out the windows and weld some metal grates instead. nothing says holocaust survivor like steel grates for windows.
6. if you could have the exhaust exit thru the hood like on the tractor pull trucks that would look bad a$$
just some things i've had running thru my mind last week.
Old Feb 21, 2008 | 08:04 PM
  #26
blkbaretta's Avatar
blkbaretta
Wider wheels make all the difference, imho.
