Driveline Shift
Old Feb 20, 2008 | 11:36 PM
WD OPN Throttle's Avatar
WD OPN Throttle
Default Driveline Shift
Hey Guys,
My 95 (5.2L 318, Auto)seems to have the entire driveline shift when taking off. I can be sitting at a light and if I accelerate with anything more than half throttle, I can feel the driveshaft vibrate, the transmission move, and the transfer case shift. The transfer case is especially noticeable because it moves enough to slam the transfer case **** into my dashboard. (Hard enough to leave marks!) can anyone offer help? I am mechanically inclined but I only know what i have already screwed up and fixed, this is not one of those things.
Old Feb 21, 2008 | 07:52 AM
dhvaughan's Avatar
dhvaughan
Default RE: Driveline Shift
wow.
broken transmission mount maybe? trying pushing or gently jacking on the transmission to see if you have a broken/missing mount bolt. or broken mount.
be careful with hard acceleration until you get this fixed. you don't want the drive shaft to come flying out.
Old Feb 21, 2008 | 08:07 AM
WD OPN Throttle
Is that a serious conern? Would driving full time in 4WD minimize the risk? (Doesn't seem to be as much flex in 4WD)
Old Feb 21, 2008 | 09:53 AM
TheForce55555's Avatar
TheForce55555
Check the rubber mount between the Transfer case and cross member........well if its even there
Old Feb 21, 2008 | 10:03 AM
dhvaughan's Avatar
dhvaughan
yes. especially if the t-case shift **** is banging into the dash. it should not be moving around.
no. its only moving less because with the front drive shaft turning, its putting more bind/torque onto the transmission and holding it place. driving in 4wd on dry pavement is a no no, as the the front/rear binding cannot slip as easily through the tires.
Old Feb 21, 2008 | 02:38 PM
zique's Avatar
zique
ORIGINAL: WD OPN Throttle
Is there rice in China?
Well, I guess it's not that serious if you don't mind replacing your entire drivetrain when the thing decides to give out completely.
