thermostat replacement
Old Feb 23, 2008 | 05:40 PM
freebird63's Avatar
freebird63
Default thermostat replacement
How hard is it to change out the stock thermostat??? I went out and bought a 180 degree thermostat today.
My bad, it was a 180 degree thermostat.....sorry
Old Feb 23, 2008 | 05:44 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: thermostat replacement
not hard but don't run a 160* you'll probably throw a code as the truck won't heat up to correct operating temp. The truck will just waste gas trying to heat the engine up.
Old Feb 23, 2008 | 05:45 PM
Shawn86's Avatar
Shawn86
160* I didn't even know they went that low! The first time you do it it's a pain in the butt, you've gotta remove a bunch of brackets and all that! I'd suggest cutting the tab off of the housing when you do it now to save you the headache later on. Other than that, it's pretty simple, I just did mine not to long ago, though I forgot to cut the tab off, damn[:@]
Old Feb 23, 2008 | 06:18 PM
freebird63's Avatar
freebird63
My mistake its a 180 degree thermostat
Old Feb 23, 2008 | 09:13 PM
1BigRamaniac's Avatar
1BigRamaniac
Treat yourself to a Chiltons or go to the DIY. Treat yourself to a nice scraper too!
