Can you change the trans. shift points or the converter lock-up with the hypertech programer
According to their website...no.
Doesn't it change the shift points itself? Or is that only in some trucks and not ours? I know you can't manually set the shift points to what you want. Atleast you can't on my 01.
You can only raise or lower the rev limiter to where you want and it only goes up or down 500rpms I think.
