Trans Temp Sensor
Old Feb 27, 2008 | 09:57 AM
WD OPN Throttle's Avatar
WD OPN Throttle
Default Trans Temp Sensor
Does anyone know what vehicle systems rely on the trans temp sensor if any?
Old Feb 27, 2008 | 11:02 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Trans Temp Sensor
-Overdrive lockout
-torque converter lockup
That's the only ones I can think off right off. Service manual could tell you for sure what else.
Old Feb 27, 2008 | 11:18 AM
dusty_duster's Avatar
dusty_duster
There's also a light on the gauge cluster labeled "TRANS TEMP" that will light up if it gets too warm.
Old Feb 27, 2008 | 12:46 PM
highlander73's Avatar
highlander73
I wonder if you can tap into this wire for an external aftermarket temp gauge instead of messing with the trans cooler lines and fluid fittings.
Old Feb 27, 2008 | 01:00 PM
Silver_Dodge
As long as you don't alter the reading with your splice, I don't see why not. Where is that wire located though?
Old Feb 27, 2008 | 01:49 PM
dusty_duster
ORIGINAL: highlander73
It could possibly work, but it might use a different voltage range than an aftermarket gauge.
Old Feb 27, 2008 | 02:32 PM
2broke4smoke's Avatar
2broke4smoke
I have a westach guage with the dipstick sensor. Super easy install and works great. I relocated my od off swith and put the guage in the cubby hole in the dash where the switch was. Makes for a super clean factory look. I know it is not the most accurate because it is not in the hot line however it is close enough to know if the trans is getting hot! I will try to snap a few pics this weekend for you but you can get the guage and stuff from genos garage for like 75 bucks for everything
Old Feb 28, 2008 | 07:43 AM
WD OPN Throttle
Will the temp light go off if the sensor is toast?
Old Feb 28, 2008 | 09:07 AM
Silver_Dodge
ORIGINAL: WD OPN Throttle
Do you mean, will the temp light come on if your sensor is bad? Or is your light on right now, and you hope it will go off if the sensor is toasted?
Old Feb 28, 2008 | 05:41 PM
WD OPN Throttle
If the sensor is bad, will the light turn on?
