Diff temp and gauge mounting
Old Mar 8, 2008 | 10:35 AM
Silver_Dodge's Avatar
Silver_Dodge
Default Diff temp and gauge mounting
I'm thinking about putting a temp sender on my rear diff cover. Anyone done this with a cover other then the Mag-Hytec cover? Don't get me wrong, it's a sweet cover, just a lot of $$$.
Second question is, where did you put the gauge? I'm thinking about putting a two gauge panel down low on the dash (below the ashtray). I'll put my trans temp guage (currently on the stereing column) and the diff temp gauge together down there. Then on my steering column, I think i'm going to put a tach.
Here is diff gauge I want to use because it matches my current trans temp gauge:
[IMG]local://upfiles/9095/D16DE5F88FC14866960D4D442123543B.jpg[/IMG]
This is my current trans temp gauge:
[IMG]local://upfiles/9095/2A01302030AB466B8D23C86B2305C34C.jpg[/IMG]
I would put them in this 2 gauge panel:
[IMG]local://upfiles/9095/32DEB68EA5BF41DF8242D70AC9E6C26B.jpg[/IMG]
and use these angle rings to point them slightly up and toward the driver:
[IMG]local://upfiles/9095/6E5B359EA44044B6B96BACC552D64A9C.jpg[/IMG]
Old Mar 8, 2008 | 12:23 PM
motorbrreath's Avatar
motorbrreath
Default RE: Diff temp and gauge mounting
why not just get a 2 gauge a pillar, and mount the tach on the steering colum.
Old Mar 8, 2008 | 12:27 PM
Silver_Dodge
I have a grab handle on the a-pillar instead. Plus, I think the gauges on the a-pillar is kinda overdone. I want them out of the way, but still visible.
Old Mar 8, 2008 | 01:21 PM
motorbrreath
i hear ya, well make sure to do a DIY when you get em in.
Old Mar 8, 2008 | 04:00 PM
Silver_Dodge
Anyone know what normal operating temps are for a diff?
Old Mar 8, 2008 | 05:55 PM
rabbler's Avatar
rabbler
I would be surprised if you see 150 Deg while towing. I've never been burned by diff oil but the covers can get quite warm. I don't think the needle on the one pictured will hardly ever move.
I can't say I've ever seen anyone with a diff temp gauge before, I think its serious over kill.
I would drill and tap the housing for the sensor. It should be pretty easy for you.
Old Mar 8, 2008 | 06:27 PM
Silver_Dodge
Everyone is telling me that 4.56 or 4.88 gears will generate a lot more heat. That's why I am wanting to monitor it. I was going to just drill and tap the existing cover, but i'm looking for one with extra fluid capacity.
Old Mar 8, 2008 | 07:50 PM
motorbrreath
i think its a good idea, but you will prolly only see it move when your towing or possible mudding, because of the wheel slip.
Old Mar 8, 2008 | 08:32 PM
pipeking's Avatar
pipeking
sorry silver u got a lot of good stuff and an awsome truck but diff temp over kill why not exaust temp
Old Mar 8, 2008 | 08:43 PM
motorbrreath
ORIGINAL: pipeking
cause its not a diesel...
