stumped on coolant loss
Old Mar 11, 2008 | 01:12 AM
rabbler's Avatar
rabbler
Default RE: stumped on coolant loss
It's not overfilling the over flow tank is it? That could be just a bad rad cap.
Old Mar 11, 2008 | 02:27 AM
kowboydmac's Avatar
kowboydmac
Funny you mentioned your wife smelling something.
Usually, only the girls can smell any sort of odor in my truck, the guys dont think anything of it.
Old Mar 11, 2008 | 09:34 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: lizardhunt
I don't smell anything in the cab. When vehicle is idling there is no smell of coolant outside of vehicle or under hood.
All fluids are clear, just changed oil and serviced tranny...all clear.
The onlycoolant that I have been able to find is the from the overflow tube itself after driving in from the house to work (15 miles). Wife smelt a hint of antifreeze in the morning a little over a week ago in the first 7 miles of trip into town. Smell stopped.
I'll have to check the hoses that aim4squirrels mentioned...never thought of a pinhole leak in the heater hoses.
I bet your heater core has pinholes in it. The smell comes and goes depending on when the coolant recrystalizes and plugs where it's leaking. I've posted pics of my heater core before where I had almost no heat, a loss of coolant, but the truck ran great and there were no signs of coolant leaking out of the HVAC box, because it was leaking just enough so as not to be seen. It took a while before the coolant smell started to become noticable.
If the wife smelled coolant, pull the heater core. Trust me.
Old Mar 11, 2008 | 12:31 PM
Baddnet's Avatar
Baddnet
and your sure the cap is good.. and not blowing coolent back into res..and then spitting it out on the ground as you drive..is engine temp normal..? might try hanging a small jug on end of overflow hose and see if it fills up...when driving.. it has to be going somewhere.. try looping your heater core hose and bypass the heater core..and see if your still loosing it.. this a strange.. it has to be going somewhere a gallon is a bunch to have to keep replacing... when you did the pressure check ..did you do both a cold test and a warm?
Old Mar 11, 2008 | 08:44 PM
lizardhunt's Avatar
lizardhunt
Lots of info to digest, and respond to...I did replace both thermostat and radiator cap. Could be that both are bad still.
I checked the overflow tube this AM after getting into town. The end of the tube was covered in fresh antifreeze. System is backing up. I'll try taping a beer bottle over the end of the tube tomorrow to see how much is leaking.
I think I will check the heater core too over the weekend to see if I can find any sign of leakage there. One strange thing abouta leak here is that I do not get moisture in the windows...I run defrost in the AM asI'm in NW Montana and I still haveover a foot of snow in theyard.
I don't smell the coolant but I'm used to the truck though.
Old Mar 11, 2008 | 09:15 PM
rabbler's Avatar
rabbler
The overflow tube off the rad, doesn't it go into its own container?
Or does it just hang there and spill on the ground if anything comes out?
Old Mar 11, 2008 | 09:26 PM
lizardhunt's Avatar
lizardhunt
The overflow off of the radiator runs into the overflow reservoir/fill reservoir. This tank sits on the passenger side wheel well and has a rubber tube (overflow) that runs down the wheel well and lets fluid run onto the ground.
The end of this rubber tube is the one that has the fresh antifreeze on it.
Old Mar 11, 2008 | 10:17 PM
rabbler's Avatar
rabbler
Oh Ok.
That sounds right. Is the over flow tank completly full?
Old Mar 11, 2008 | 10:28 PM
lizardhunt's Avatar
lizardhunt
No, it is about halfway between add and full mark.
Last night I filled it up to just over full to allow for air pocket displacement.
Old Mar 11, 2008 | 10:36 PM
Baddnet's Avatar
Baddnet
Don't tape the bottle so air can't escape..or it might blow the bottle off.. :P
Might even want to flush the engine and radiator..
