Do I need a chip reprogrammer?
Old Mar 9, 2008 | 09:43 PM
freebird63's Avatar
freebird63
Default Do I need a chip reprogrammer?
Ok I have a 2000 dodge ram 1500 with the 5.2 liter engine, its stock, except for the K&N air intake system. I also has taller tires then stock, I found that when I am in overdrive and using cruise control and come to a small rise in the road it shifts out of overdrive into "D", then if the rise is more...like a small hill, it shifts into "2nd", this causes the rpm's to jump up to almost 4500, when towing a trailer its even worse and gas mileage suffers really bad. So would it be in the best interest to get a chip reprogrammer??? and which kind is the best one to get??????
Old Mar 9, 2008 | 09:53 PM
jperkins812's Avatar
jperkins812
Default RE: Do I need a chip reprogrammer?
You could get a Hypertec, it will let you change shift points, calibrate for larger tires, etc. It should help you out with a few of your problems that you are having.
Old Mar 9, 2008 | 11:43 PM
aim4squirrels's Avatar
aim4squirrels
you shouldn't tow in OD.
it's not a chip problem, it's a gearing problem.
