Removing front axle hub/ axle shaft.help please
Old Mar 10, 2008 | 09:12 PM
lizardhunt's Avatar
lizardhunt
Default RE: Removing front axle hub/ axle shaft.help please
Good luck...supposed to be somewhat of a pain in the butt, if you do the seals the third member has to come out.
Old Mar 10, 2008 | 10:32 PM
Shawn86's Avatar
Shawn86
When I did my U-joints I used a ten foot piece of galvanized fence pole to break it loose and it still gave me a little hell. But only a little! And I'm pretty sure it's just a standard thread, I've had to pull 'em a couple different times for different reasons.
Old Mar 11, 2008 | 12:52 AM
robinbobin's Avatar
robinbobin
ORIGINAL: Shawn86
cool thanks for the info... ill give it a go with a longer piece of pipe. if ten ft gave u trouble maybe ill go 15 hhahah
Old Mar 11, 2008 | 07:13 AM
dhvaughan's Avatar
dhvaughan
see here for special tools and hard to find parts.
including the right side axle bushing.
QT1072 is a front hub puller.
http://quad4x4.com/4x4%20Tools.htm
[IMG]local://upfiles/38819/668CD991933D47E09C2D2C70311BF7EC.jpg[/IMG]
Old Mar 13, 2008 | 05:27 PM
Slomojo's Avatar
Slomojo
yeah now there is an idea. pull out the ugly stick that's not even used for the ugly kid across the street that's 15 feet away.
Old Mar 13, 2008 | 10:01 PM
erikb45's Avatar
erikb45
i just did my ball joints yesterfay and air chisel and a BFH and if that dont work get a bigger one!!!
the good news is once you get them off they come off easier the next time
Old Mar 17, 2008 | 07:58 PM
robinbobin's Avatar
robinbobin
update- i finally got the ball joints done a u joints also.
it took me 5 feet of pipe, and an oxy/acyt torch to get the axle shaft nut off.. want to know why? cause whoever messed with this thing before crossthreaded the dang thing. not fun so that was about antoher $150 down the drain. as for the hub that was pretty easy a 9/16 socket and bfh did it pretty easy. so i got everything out clean it all up replcaced the ball joints no problem at all. u joints thats different story. ah the u joints.. lets see for an our i tryed getting the clips off because they where so welded on. got all for off and then pressed two sides out no problem. got the the inner shaft and could not get the caps off.. so i went with the angle grinder grinded off part of the joint yes i got it off.. but wait... as i look to my right im frickin on fire from the sparks. lol know what this means? a drive the local party store for a 12 pounder of bud.mmm.. had few and went to install new u joints. o wait autozone sucks and gives me the wrong ones haha. so the next day got new joints in and from there on it went smooth as butter. thats my first experience with 4x4 front ends not bad for a rookie a?
Thank you to everyone for the great ideas. i couldnt have done it with out you guys
