What should I look for?
Old Mar 10, 2008 | 12:55 PM
hometheaterman's Avatar
hometheaterman
Default RE: What should I look for?
ORIGINAL: stevenf
it will still be more fuel efficient then my 1989 Bronco II @ 12mpg
So you would recommend putting a thermostat on the trans? What temps should it NOT reach?
I wouldn't count on it. I don't know what the V6's get mpg wise but I get around 12mpg with my V8 if I drive it easy and in the 10's if I drive it like I like too and it seems like people say the V6's don't really get any better gas milage.
As for the transmission I don't know much about the ligheter duty transmission behind the V6 but for the 46RE thats behind the V8's it just has a lot of common issues. It's pieces inside that don't hold up. I've heard of some failing from heat but most of them seem to be from one of the many issues these transmissions have. You can't fix that without a rebuild and getting parts from a place like APS or similar that are better and fix these issues.
There is also a check ball in one of the lines that seems to like to go and not let the fluid get to the transmission. I'd probably put a nice B&M or similar cooler on there and remove that check ball. I've just heard you need to let it warm up in Neutral if you do that for a few minutes. It's supposed to not move according to 1 or 2 people I've seen on here if you don't. I've never had that but it's supposed to drain the Torque Converter of fluid or something like that.
As others said I wouldn't even think about the V6. IMO these trucks are pretty slow and underpowered and thats with my 5.9L V8 I can't even imagine how bad a V6 would be.
Old Mar 10, 2008 | 01:56 PM
stevenf's Avatar
stevenf
Can you give me a link to a good transmission cooler? What would I be looking at paying for one?
Old Mar 10, 2008 | 02:21 PM
dusty_duster's Avatar
dusty_duster
ORIGINAL: stevenf
Here's a decent one:
http://store.summitracing.com/partde...p;autoview=sku
Old Mar 10, 2008 | 04:13 PM
hometheaterman
http://www.jegs.com/p/B%26M/758370/10002/-1
Old Mar 10, 2008 | 06:53 PM
lotec25's Avatar
lotec25
I have a 99 V6 with the manual. And it runs fine for me. It will even break the tires loose. The gas milage is not that great. But i got it for a good price so i jumped on it. I did a tune up on it when i got it. Has 78000 on it. Had no problems since i got it. Who ever had it before me took the Cat off and did a crap job when the put the straight pipe in and i need to replace it.
[IMG]local://upfiles/60870/D8A406845AFD4493BF7D4F516BB0BF31.jpg[/IMG]
Old Mar 10, 2008 | 09:13 PM
98DodgeRam1500's Avatar
98DodgeRam1500
ORIGINAL: stevenf
Im not getting it for fuel efficiency. Im getting it because I know the man took care of it and he only wants $2,400.00 for it with 106,000 miles. No matter what it is, it will still be more fuel efficient then my 1989 Bronco II @ 12mpg
in your original thread you asked what to expect for mileage...
Get a tranny cooler, the one with plates, not tubular. you can find them for $50-100
Get a tranny gauge temp kit. $40-80 normal operating range from what I was told was 150-190*F. over 210 is bad. some gauges will show you the temp range in colors like a tach.
Get the tranny serviced (new fluid and filter, get the bands adjusted) -$90-110
check the front bearings, they go around 100k
look for rust on the drivers and passenger side along the bottom (if your roads are salted in the winter)
Other than that, I don't know what the other typical issues are known with the V6.
Fora beater work truck sounds like itsdecent.
