Remote start
Old Dec 26, 2004 | 02:59 PM
Blylock's Avatar
Blylock
Default Remote start
I have a 98 Dodge 1500 SLT 5.9L, i need to install my new remote start, would anyone happen to have a wiring diagram for the ignition harness or have knowledge on which colors are for
12v power
Accessory
Start
Old Dec 26, 2004 | 03:28 PM
Snafu's Avatar
Snafu
Default RE: Remote start
Do a search on the web. I got an inline harness adaptor for my '97, made it MUCH easier to install. Just take the bottom cover off the column, unplug the flat harness, and plug the T-harness inline. Takes care of all that. Not sure where I got mine from, it's been a year, maybe check Ebay...
Old Dec 26, 2004 | 03:51 PM
Ramtuff's Avatar
Ramtuff
Constant 12V is red and pink/black
starter is yellow
12v accessory is back/white
Old Dec 28, 2004 | 03:40 AM
Scootr's Avatar
Scootr
The mfg of the remote starter should have a web site with wiring diagrams for your particular truck. I know Bulldog along with another popular remote starter mfg( can't remember the name of it right now) have their own sites with this info.
Old Dec 31, 2004 | 05:15 PM
trinidad's Avatar
trinidad
I found wiring diagrams at http://www.designtech-intl.com. These were not 100% accurate but the installation guide does walk you through testing which lines do what. I did my 01 Ram 1500 and it was pretty easy. Good luck
Old Jan 2, 2005 | 06:26 PM
Blylock's Avatar
Blylock
Thanks guys for all your help, but im stuck on 1 aspect. Everything works fine, the acc, heat, safety swithces. My parking lights do not flash. ive hooked the white up to the blk/yellow which is the + on the switch, also the green/white which is the -, both do not flash the lights. any suggestions?
Old Jan 3, 2005 | 04:12 AM
Ramtuff's Avatar
Ramtuff
The black/yellow is the correct wire. A lot of times, the parking light flash feature can be turned on/off. Check manual that came with your unit and see if you have to activate it.
