Dodge QC
Old Mar 11, 2008 | 08:23 PM
castironman's Avatar
castironman
Default Dodge QC
Hello, guys, I had a new one this weekend. Coming out of the parking lot, I turn right and a noise came from the driver's side, I stop the truck, open the hood: belt was off, the shaft and pulley of my steering pump came off from the impeller...first time ever. Got new pump from autozone with the special removal tool (we had to use a impact wrench to remove the pulley from the shaft - the sales guy was very helpful), back on the road. Have you see something mechanically amazing with your Dodge? I think the truck is very well design ( just some flaws, distributor, crank sensor,starter bolts... ) but weak with the parts quality (heads, transmission...).
Old Mar 11, 2008 | 08:50 PM
rabbler's Avatar
rabbler
Default RE: Dodge QC
That's not that uncommon. The pump shaft or the vane pump snaps. Good thing you stopped and checked. I've seen a few where the pulley/shaft comes all the way out gets hit by the fan and tossed into the rad.
Did you run a couple bottles of fluid through the system to flush out any possible shrapnel?
Old Mar 11, 2008 | 09:49 PM
TheForce55555's Avatar
TheForce55555
Destroyed 9.25 housing, my buddy was burnin tire in first gear and grabbed second at about 5000 grand
Old Mar 11, 2008 | 10:02 PM
rabbler's Avatar
rabbler
Ouch! what happened?
Pinion snap?
Old Mar 11, 2008 | 10:04 PM
TheForce55555
Yes the pinion gear snapped off the shaft......creating the hand-grenade effect
Old Mar 11, 2008 | 10:24 PM
rabbler's Avatar
rabbler
That would do it. [:@]
