no cat
Old Mar 11, 2008 | 09:43 PM
vikdale's Avatar
vikdale
Default no cat
I have removed my cat on my truck and the service engine lite came on as i thought .Is there any trick to making it not come on at all?
Old Mar 11, 2008 | 09:51 PM
pipeking's Avatar
pipeking
Default RE: no cat
ya,now you dont have an o2 sencer.but before i tell you what you need and where to go howw did you do it.did you replace your y pipe,or just cut it out and put a pipe in its place.do you notice more power or is your foot in the theottle more for the sound.
o2 sim www.fastman.com
Old Mar 11, 2008 | 10:07 PM
TheForce55555's Avatar
TheForce55555
Default RE: no cat
Are you sure the its the SEL light not the CEL light?
Old Mar 13, 2008 | 04:01 PM
vikdale's Avatar
vikdale
Default RE: no cat
ya it is the check engine light that is on .I still have the two o2 sensorsjust no cat . the cat was plugged so there is a gain in power.
Old Mar 13, 2008 | 09:17 PM
blkbaretta's Avatar
blkbaretta
Default RE: no cat
Just put some O2 simulators in there and it should fix the problem.
Old Mar 13, 2008 | 09:19 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: no cat
Only the rear 02 sensor can be simmed. The front one controls your fuel mixture.
Old Mar 13, 2008 | 10:16 PM
kowboydmac's Avatar
kowboydmac
Default RE: no cat
Yeah I was curious about that Cereal, if you modify the first o2, don't you risk the chance of running very, very rich while idling horribly?
Old Mar 13, 2008 | 10:43 PM
Cereal Killer
Default RE: no cat
exactly.
Your gas mileage will likley get cut down to about 2/3 of what it use to be.
Old Mar 13, 2008 | 10:52 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: no cat
some cat nip should make it come back.
