ball joint torque ASAP
Old Mar 12, 2008 | 06:54 PM
erikb45's Avatar
erikb45
Default ball joint torque ASAP
need ball joint torque right away please 2001 4wd
Old Mar 12, 2008 | 07:31 PM
Parts/Service's Avatar
Parts/Service
Default RE: ball joint torque ASAP
Dana 44
[ol][*]Install and tighten lower ball stud nut to 108 N·m (80 ft. lbs.) torque. Advance nut to next slot to line up hole and install new cotter pin.[*]Install and tighten upper ball stud nut to 101 N·m (75 ft. lbs.) torque. Advance nut to next slot to line up hole and install new cotter pin.[/ol]Dana 60
[ol][*]Install and tighten lower ball stud nut to 47 N·m (35 ft. lbs.) torque. Do not install cotter pin at this time.[*]Install and tighten upper ball stud nut to 94 N·m (70 ft. lbs.) torque. Advance nut to next slot to line up hole and install new cotter pin.[*]Retorque lower ball stud nut to 190–217 N·m (140–160 ft. lbs.) torque. Advance nut to next slot to line up hole and install new cotter pin. [/ol]
Old Mar 12, 2008 | 07:35 PM
rabbler's Avatar
rabbler
Can't say I ever torqued one.
It should be tight but don't stand on it or anything.
The torque isn't critical as you have to line up the castle nut for the cotter pin anyway.
Always tighten the bottom first!
