AC Compressor
Old Dec 27, 2004 | 10:55 AM
banwhalen's Avatar
banwhalen
Default AC Compressor
Question...
I fired up my 98 Ram the other day and heard a slapping kind of sound coming from the front of the engine, I think that's a belt problem (flat spot) as it is kind of old and had sat for several days in the cold weather, started to quiet down when the engine warmed. I am replacing it today with a new one. Anyone know if the Dayco belts are better than oem?
My question is: when I was trying to figure out the noise from the belt, I turned on the a/c and noticed that I did not hear the normal on off of the a/c clutch. When I turn on the a/c, shouldn't I hear the compressor engage? I realize that it was only in the lower 30's outside, but that shouldn't affect it. Could the belt be the culpret? The noise that I heard and believe is the belt was coming from the left side of the front of the motor near the coil. The a/c compressor was not making any noise. Maybe a loose connection. I just thought that I should hear the compressor engage.
Any insight would be much appreciated.
vr,
Eduardo Banwhalen
