Finally 4.10 gears
Old Mar 13, 2008 | 10:50 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default Finally 4.10 gears
I finally bit the bullet and ordered up a set of 4.10 gears. The fronts include the carrier, ring and pinion, and the rear ring and pinion are Richmond manufacture. $275 plus $35 shipping for the entire package.
My mechanic told me $250 per axle to install, so now I've gotta gather my new rear axles ($116 each at Summit Racing), 7 new U-joints ($20 each at Summit Racing), and front and rear install kits ( about $130 each at Randys Ring and Pinion).
So for about $1500 I'll have everything re-geared and will be able to haul a**** and my camper.
Old Mar 13, 2008 | 11:15 AM
mopowar's Avatar
mopowar
Default RE: Finally 4.10 gears
That's a good deal. It cost me $1800.
Old Mar 13, 2008 | 11:18 AM
Silver_Dodge's Avatar
Silver_Dodge
Mine also cost about $1800, but that also included the purchase and installation of an Auburn limited slip at the same time.
Old Mar 13, 2008 | 12:51 PM
turkeyhunter1962
Can't afford to upgrade the rear carrier to a limited slip so am just using the one that came with the truck. If it wasn't for the upgraded axles and $140 in U-joints (no use putting the old ones back in) I could save myself about $370 +.
Old Mar 13, 2008 | 01:04 PM
Mike Roma's Avatar
Mike Roma
Nice!
Mine's going to cost slightly more than that for 2wd!
Old Mar 13, 2008 | 01:09 PM
turkeyhunter1962
ORIGINAL: Mike Roma
Nice!
Ouch!!!! Who saw you coming up the sidewalk with cash in your hand? What you installing?
Old Mar 13, 2008 | 01:14 PM
Mike Roma's Avatar
Mike Roma
4.56's and a LSD. Forgot about the LSD, and your just getting gears, right?
Old Mar 13, 2008 | 01:15 PM
turkeyhunter1962
Rear ring and pinion and front ring, pinion, and carrier. I'm also installing all new u-joints and new rear axles.
Old Mar 13, 2008 | 01:59 PM
HammerNailKid's Avatar
HammerNailKid
Hey Guys,
I've read just about every thread on hereregarding gears and can't find a definitive answer. Not to mention the fact that the mechanics around here are no help. You can see my truck stats below. I'm running 285's on stock gears. I know I should upgrade, but I don't know what to. The biggest I'll probably ever go on the tires is 35's. What gearing should I go with??????
Thanks a ton,
Old Mar 13, 2008 | 02:00 PM
hometheaterman's Avatar
hometheaterman
I got my Auburn LSD for $357 from Rye Valley Gear and Oil then had to pay $14 something shipping but I was in the same state. Might be more if I was in a different state. do you have the open diff now or the LSD? If you have the LSD I'd upgrade it before it goes out on you.
http://auburngear.com/aftermarket/su...p;sid=Virginia
There is the info for the place I got mine. It was the cheapest I found.
