Oil Pressure is dropping off.
Old Mar 17, 2008 | 01:28 PM
rickett75's Avatar
rickett75
Default Oil Pressure is dropping off.
After about 15 minutes of driving my truck the oil pressure is dropping off. It starts out fine in the 40's and after I drive for a bit, itdrops to zero when I'm at idle. Any idea's? Sending unit? Oil pump? Guage? Or worse?
Old Mar 17, 2008 | 01:50 PM
rabbler's Avatar
rabbler
Default RE: Oil Pressure is dropping off.
I would verify oil pressure with a mechanical gauge.
(Unscrew sending unit and install mechanical gauge)
If it still drops way low pull the oil pan and inspect. If the pick-up screen is plugged you can probably clean it out and be OK.
If it is fairly clean you probably have worn out crank and rod bearings.
Any noise from the engine when the oil is hot? Lifter clatter is usually the first sign.
Old Mar 17, 2008 | 01:53 PM
rickett75's Avatar
rickett75
No, there is no engine noise after the engine warms up, or after the pressure starts to drop.
Old Mar 17, 2008 | 02:13 PM
rickett75's Avatar
rickett75
Oh, and by the way, thank you for the assistance.
Old Mar 17, 2008 | 02:25 PM
rabbler's Avatar
rabbler
No prob
Like I said best to verify oil pressure with a mechanical guage before jumping to conclusions.
Old Mar 17, 2008 | 03:07 PM
fivenine ram's Avatar
fivenine ram
best to get that mechanical guage hooked up asap i procrastinated and ended up blowing the motor
