Crank Driven Fan to Electric Fan Conversion
Old Mar 23, 2008 | 12:22 PM
Boardingkaos's Avatar
Boardingkaos
Default Crank Driven Fan to Electric Fan Conversion
Has anyone done it? I just got my first dodge (1998 ram sport 318ci)
I plan on using it to drag race this season and my friend who has a Dakota told me about replacing the crank fan with an electric one to get a decent amount of power. How can i do this and what electric fan do i need to get to do it?
Thanks,
Chris
Old Mar 23, 2008 | 12:29 PM
SST2713's Avatar
SST2713
Default RE: Crank Driven Fan to Electric Fan Conversion
Im not all too familiar with the swap, all im curious about is whether or not you need a new type of water pump. Then again.....does anyone know if the fan clutch just unbolts and can be taken off?
Old Mar 23, 2008 | 12:34 PM
aim4squirrels's Avatar
aim4squirrels
Just take the old fan, clutch, and shroud out and replace with electrics. Not that hard, gains you back a little power, about the amount that might get sucked up by running the Air Conditioner. It gives you lots of engine bay room back.
No need for a new water pump.
Old Mar 23, 2008 | 01:12 PM
RM_Indy's Avatar
RM_Indy
Lots of guys with r/c s/b use the Flexalite Black Magic fans, Ive got their 210B's on mine cause of the color. Some will get them from the wreckers from Ford midsize cars as well. Adds a bit of hp off the line mainly. Dont expect a lot.
Link below lists various bolt ons I added and how they affected my 5.9s 1/4m ets if you need some other ideas.
http://www.rm-indy.com/Performance_Gains.htm
Few other pages here that maybe of interest. Track prep for my Ram, weight reduction etc etc.
http://www.rm-indy.com/tech.htm
Cleans up under the hood as mentioned so you can clutter it up with better things
http://www.rm-indy.com/images/polished%20D-1SC_2.jpg
Old Mar 23, 2008 | 03:47 PM
motorbrreath's Avatar
motorbrreath
use the search feature. alot of people have done this. padodgeram is selling some with a custom shroud in the parts section under classifieds.
Old Mar 23, 2008 | 09:49 PM
1BigRamaniac's Avatar
1BigRamaniac
After you do this, you can start to worry that your waterpump impeller is costing you RPM at high speeds. You therefore have to go electric there too. I have heard if you live in colder climates, you can take you fan off for 3-4 months.
Old Mar 23, 2008 | 11:18 PM
DPR250R's Avatar
DPR250R
I used one off of a Mark VIII with a SPAL controller... perfect...
Bolts into the shroud nice..
