need help badly
Old Mar 23, 2008 | 03:03 PM
myakkacracka's Avatar
myakkacracka
Default need help badly
hello i have just purchased a 1995 dodge ram with the 5.2L as soon as we left and the engine warmed up it started to idle rought and die if you were in drive and stoped. as long as you were driving it ran great. i came home and let it sit and while it was cool it ran fine but when it hit 180 degree or so it would start to run bad again. i checked all the vacum lines an it has plenty of fuel pressure. can any one help me out. Thanks
Old Mar 23, 2008 | 04:03 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Default RE: need help badly
return it.
Old Mar 23, 2008 | 04:14 PM
rabbler's Avatar
rabbler
Check o2 sensor.
Old Mar 23, 2008 | 09:17 PM
tosh1953's Avatar
tosh1953
Junior Member
You may want to check the engine coolant sensor.
Old Mar 24, 2008 | 01:34 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Check the oil level. If you have a plennum leak you may have low oil level.
Old Mar 24, 2008 | 11:53 AM
Racinfan83's Avatar
Racinfan83
Idle air control motor (IAC) on the throttle body may be dirty. Give your tb a good cleaning.
Old Mar 25, 2008 | 08:55 PM
Gene563's Avatar
Gene563
+1 on the IAC. I was having a similar problem.
I cleaned the TB, IAC and theTPS( Throttle Position Sensor )as well.
I ended up replacing the IAC andit seems to be OK now.
Old Mar 26, 2008 | 07:21 PM
99grannydodge's Avatar
99grannydodge
Try Rabbler's suggestion. O2 sensor fixedmine.
