Powersteering Pulsing
Old Mar 24, 2008 | 02:58 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Default Powersteering Pulsing
Well I now have a new problem.. When i am turning corners (like driveways, or sharp corners). The powersteering pulses and the pulses are rythmic.. I jus wanted some opinions because ps pumps are expensive.
Old Mar 24, 2008 | 06:23 PM
BadHab1t's Avatar
BadHab1t
Default RE: Powersteering Pulsing
is it making a constant click noise cause my ps pump is and its drivin me nuts just started it like a block away and i think its the bearings i can see my wheel wobble a lil bit but i have no leak...kinda odd but maybe someone will chime in and help us both out sorry if jacked ur thread.....j
Old Mar 24, 2008 | 07:27 PM
jasonw's Avatar
jasonw
Site Moderator
I had the pulsing you are describing. I was also afraid it was a power steering pump or worse. Took it in for a squeak as well (bad u-joint) and they discovered that the ball joints were going bad.
Replaced them and u-joints, and all is well now.
EDIT: Oh, almost forgot. If you don't do the job yourself, parts + labor + tax will run you about $750 for front ball joints. On the good side though, mine came with lifetime warranties.
