98 99 engine swap
I've got a 99 dodge ram 4X4 with the 5.2 and about 250,000 miles on it. I've located a 5.9 out of a 98 1500 ram 4x4 sport with half the miles. What's the pros and cons and will they swap?
Thanx in advance for your help!
Robert
Robert
Thanx for fast response. I can get anything i need off the 98 - it was rear ended! Do i need the harness also? All the acc. are the same - alternator, PS pump, A/C comp. Only difference I saw was the 98 had ABS and mine doesn't
Thanx
Robert
Thanx
Robert
Should swap right in. Make sure you keep the original flex plate and balancer on the 5.9
You might need to swap a few sensors but only if the connectors are different.
I haven't tried it but I wouldn't be surprised if the 5.2 PCM runs the 5.9 just fine.
