Truck runs good/ trans shakes a bit when cold
Old Apr 1, 2008 | 01:25 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Default Truck runs good/ trans shakes a bit when cold
I noticed the other day that when i start up an it is cold it shakes a bit when i drive. not much but it is noticeable when i drive reall slow. and when i have my foot lightly on the break it an stoped it seems to shake. should i be worried?
Old Apr 1, 2008 | 02:46 PM
wvjefo's Avatar
wvjefo
Default RE: Truck runs good/ trans shakes a bit when cold
Probably not. Maybe your engine waking up. If you are worried first place to check is motor mounts.
Jeff
Old Apr 1, 2008 | 04:20 PM
Blaydrnnnr's Avatar
Blaydrnnnr
Mines been doing that ever since I got it... the TB swap helped...cleaning the IAC helped alittle.. but it still does it alittle... I still have a blown plenum.. soon to be repaired.. I'm hoping fixing that will help.. I've been told a vacuum leak can cause an erratic idle
Old Apr 2, 2008 | 08:21 PM
Ram2K1's Avatar
Ram2K1
Yeah, mine does it, too. It's just all that power wanting out.
