piecing together a lift
Old Apr 4, 2008 | 01:48 AM
gotmud1's Avatar
gotmud1
Default RE: piecing together a lift
ive been looking into a 4" shackle flip but cant find anywhere that sells it Help
also what all is involved ive been reading about the pinion angle and a zero rate shim?
Old Apr 4, 2008 | 08:36 AM
mstephen89's Avatar
mstephen89
if your only going to lift the rear four inches i would go with a aal, or different springs.
Or someone a few days ago puta thing where you could do a 8 inch shackle flip, and then lose the stock block for a four inch lift and then you would buy a zero rate block. I think that setup would minimize any axle hop.
Old Apr 4, 2008 | 10:09 AM
dusty_duster's Avatar
dusty_duster
I've never lifted a truck, but a 5" coil spacer just seems dangerous to me.
Old Apr 4, 2008 | 02:53 PM
shawnsack's Avatar
shawnsack
ive bought 2 inch spacers from topguncustoms before and they were by no way cheap or weak looking but there is no way i would buy a 5 inch spacer... thats much tourgue and leverage on something like that especially if you plan on doing anything hardcore would only lead to disaster that is for the ocasional driver who just wants a high truck to run through town with and get some looks....
Old Apr 4, 2008 | 08:56 PM
Chopper1's Avatar
Chopper1
Just to let you guys know. I have the 6" Dick Cepek long arm set up and it is a very involved install. Most sites have their directions on the site. It is a good idea to look them over before purchasing.
Old Apr 5, 2008 | 02:46 AM
gotmud1's Avatar
gotmud1
so i think im gonna get a 3" aal fo the rear and longer shocks
the front however is still a mystery.
i found both 3" springs and 6" springs(to remove the spacer)
cant find control arms
do i need brake lines?
found pitman arm
found track bar bracket
cant find sway bar drop
what am i missing?
Old Apr 5, 2008 | 11:59 AM
mstephen89's Avatar
mstephen89
http://www.extremesuspensions.com/st...products_id=78
here are the arms that you need to buy. (I think to install these you have to weld a bracket on the frame. If you do not have a welder, be prepared to pay someone to do it for you.
Yes you will need brake lines. I think you can buy them at skyjacker.com
As for the sway bar, buy longer links for a TJ. What I would do is get the whole thing done, and then drive it to an offroad shop, and they will be able to measure to see how long yours will need to be.
The only thing I can see that you are missing is a track bar. I see that you found a bracket, but I would personally buy an adjustable track bar. I think it would be much stronger this way.
