95 Dodge Ram 1500 SLT
Old Jan 5, 2005 | 11:40 PM
Lonewolf1269's Avatar
Lonewolf1269
Default 95 Dodge Ram 1500 SLT
Have a 95 Dodge Ram 1500 SLT w/ 8cyl 318 eng. Truck will not start.Thought it was the fuel pump but was wrong. Can here the pump when key is in "on" position. Has fresh gas and has 3/8 th of a tank. Is there a fuel relay or sensor that might be bad?Anyone with any info plz get back w/me. It's to nice of a truck to let sit in the yard.
Old Jan 8, 2005 | 04:36 AM
HemiMan02's Avatar
HemiMan02
Default RE: 95 Dodge Ram 1500 SLT
check to see is someone unplugged your coil. i would say check your crank sensor but thats burried and nearly impossible to get to but someone could have cut the wires.
Old Jan 8, 2005 | 05:12 AM
Ramtuff's Avatar
Ramtuff
Check for fuel and spark. Pop off a plug wire, stick a screwdriver in the end, and lay it on a piece of metal, then crank it. You should be able to see a spark jump from the screwdriver. Check for fuel by hooking up a pressure gauge to the diagnostic port on the fuel rail over the intake manifold.
