front axle u-joint replacement
Old Apr 13, 2008 | 08:09 PM
indebtuptomyears's Avatar
indebtuptomyears
Default front axle u-joint replacement
Hi, I need to replace the u-joints on the front axles on my 96 1500.[:@]
can anyone tell me if I have to do anything special on the passanger side
with the CAD unit or will the axle shaft just slide out after I get the hub off ?
Thanks.
Old Apr 13, 2008 | 09:18 PM
XXL 1500's Avatar
XXL 1500
Default RE: front axle u-joint replacement
slides right out.
Might have to rotate the shaft while
re-installing to get the shaft to slide into the sleeve in the CAD.
Old Apr 13, 2008 | 10:09 PM
indebtuptomyears
Ok thats what I wanted to hear. Thanks
Old Apr 13, 2008 | 10:19 PM
TheForce55555's Avatar
TheForce55555
Make sure you clean the axle tube out, I just changed my U-Joints today..imagine that. If you get any dirt on the shaft while installing it, the seal will leak, which is not very good. I had to park my truck like retard for like a year so the diff fluid wouldnt run out
Good luck
