Tranny temp gauge
Old Apr 14, 2008 | 10:11 PM
Gmanf's Avatar
Gmanf
Default Tranny temp gauge
I just got a tranny temp gauge for my truck and want to know if there is a place i can hook it up in the tranny. I don't have a drain plug in the pan and i don't want to cut the line if i can go another way.
I have a 95 2500 4x4 with the v-10 engine.
Old Apr 15, 2008 | 09:43 AM
sawtooth's Avatar
sawtooth
Default RE: Tranny temp gauge
On my '96, 5.9, gasser, removed tranny drain-back check valve located onpassenger side in-line with the torque converter output and connected to the lower radiator. Obtained a T-fitting from a hardware store. One end screws(mechanical connection)into the tranny out line, purchased a barbed hose connection for the second connection and about a 1.5 ft of tranny hose that goes to radiator.The tranny temp sensor screws into the third T. AsI remember all plumbing was 3/8" ID.
Old Apr 15, 2008 | 09:47 AM
RM_Indy's Avatar
RM_Indy
Have my Auto Meter sensor in the spot provided at the back of the MP deep pan
Old Apr 15, 2008 | 09:35 PM
Dtruck96's Avatar
Dtruck96
I placed mine at the rear of the passenger side. If you look at the passenger side corner of the pan and then follow it straight up you will see a little bolt sticking out. That was the place recommended by the guys at Dr. Evil Trans when I bought mine.
Old Apr 16, 2008 | 03:04 AM
rabbler's Avatar
rabbler
ORIGINAL: Dtruck96
I think that is the line pressure test port. Thats where I would install it.
If I had one...
Old Apr 18, 2008 | 06:09 AM
Gmanf's Avatar
Gmanf
Thank yall for the info!!
