Hissing noise
Old Nov 10, 2008 | 06:24 PM
Vader's Avatar
Vader
Originally Posted by jason.w
If its not a vacuum leak, and the seal between the TB and air cleaner are fine, its either the 14x3 air intake or the CAI intake, I bet you. Both my wife's CAI K&N and my 1995 Dakota with the 14x2.5 K&N that I used to have did it. Perfectly normal.
My two cents.
Mine still has the stock type filter and the stock air box. Just want to be sure that something isn't wrong. Don't want passengers thinking that I'm having gas.
Old Nov 10, 2008 | 06:28 PM
vmann's Avatar
vmann
my kind of "kues" its not much of a hiss. kuuuuuuuuuuuuuuuuuuuuuuuuuuuuu kuuuuuuuuuuuuuuuuuuuuu but only when i am easy on the throttle
Old Nov 10, 2008 | 06:31 PM
Vader's Avatar
Vader
I guess a lot of owners have this, must not be too bad.
Old Nov 10, 2008 | 06:33 PM
jasonw's Avatar
jasonw
Site Moderator
LOL. Did you put in a K&N filter into the stock box? You might hear it a little then, maybe. Otherwise I'd check the seal between the box and the TB (if you haven't already), the stock air box can be difficult to reseat properly.
Old Nov 10, 2008 | 06:45 PM
Vader's Avatar
Vader
I'll check it, thanks Jason.
Old Nov 10, 2008 | 08:17 PM
aim4squirrels's Avatar
aim4squirrels
I had a cracked vac tube that went into the MAP sensor that made a hiss. Check the tube that goes straight into the front of the TB.
Old Nov 10, 2008 | 10:46 PM
Laramie1997's Avatar
Laramie1997
If thats the line i think your talking about... Wouldnt screw with the idle? had the same little peice of hose crack out and the truck idled at 2500 rpm
