Timing Questions
Old Apr 25, 2008 | 05:39 PM
Blaydrnnnr's Avatar
Blaydrnnnr
Default RE: Timing Questions
There are marks on the gears....on stock gears... the cam gear usually has a dot...on the crank gear.. stock has a dot too... on upgrade gears.. the cam should have a dot.. the crank will have numbers...-2, -4, -6, -8, 0, +2, +4, +6, +8...with a keyway slot on each number. Best thing is what I think you said you did...line up the marks before taking the gears off.. the cam gear dot at the very bottom at 6:00the crank gear at the top at 12:00...take them off.. slip the new ones on..dont move anything until the chain is on and the gears have slid on the keyways.. tighten the cam gear...torque it...
Old Apr 26, 2008 | 10:13 AM
kowboydmac's Avatar
kowboydmac
Well I didn't line them up, as I noticed they were keyed. I can understand it's best to find out the slack and all for the 6 and 12 lining up, I just couldn't get it to crank by hand. IDK if your spose to remove the spark plugs or what, so I just decided that it'd be ok as long I slid them on the keys without moving anything. Also, I couldn't torque it, so we used the air drive to tighten it, and then marked a line and tightened it just about 4-5 mm past that. You can't torque it with a wrench because it will move around, unless you use the screwdriver method which I didn't.
