White smoke in passin gear.
Old Apr 18, 2008 | 08:42 PM
Gwub2005's Avatar
Gwub2005
Default White smoke in passin gear.
When I floor my truck and it down shifts into passin gear a good amount of white smoke comes out of my exhaust. I call it my "smoke screen" b/c after i pass some one they are covered in smoke.[:'(] What would be a cause of this? Also i discovered oil around my spark plugs on the passenger side I think i might have a leaking valve cover what do u ya'll think? Thanks in advance.
Old Apr 18, 2008 | 10:25 PM
padodgeram's Avatar
padodgeram
Default RE: White smoke in passin gear.
leaking valve cover will smoke under the hood not the exhaust , valve seats will cause smoke out of the exhaust so will bad ringson a piston, time for a compression test..
Old Apr 18, 2008 | 11:14 PM
mstephen89's Avatar
mstephen89
definately in need of that, also check the plenum, if oil is getting mixed with the fuel I think that would smoke
Old Apr 19, 2008 | 01:34 AM
dillonjm's Avatar
dillonjm
Typically white smoke signals coolant burning though, so if it really is white I'd check to see if you're losing any coolant first.
Old Apr 19, 2008 | 02:02 AM
timsalas's Avatar
timsalas
Park it floor it and smell it?
Old Apr 19, 2008 | 08:38 AM
turkeyhunter1962's Avatar
turkeyhunter1962
ORIGINAL: dillonjm
+1 You are right.
For smoke coming out the exhaust this is typically the issue:
1) White smoke = coolant
2) Blue smoke = oil
3) Black smoke = fuel
If you are pouring out true white smoke, you're getting engine coolant into the engine cylinder somehow. Possibly a small head gasket leak that doesn't show much except under high RPM's or you've the dreaded cracked head near the valves. Either way it will only continue to get worse.
