How To Replace Ball Joints?
Old Apr 23, 2008 | 08:30 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: How To Replace Ball Joints?
ORIGINAL: Slomojo
Ball joints are fun. If you got a 2WD truck, I guess you can say, "Hammer time." I've yet to have to do my uppers but to remove the lower ball joints your just going to need a ratchet, some sockets, a ball joint install tool kit, and a 5lb hammer. Not too difficult, but be sure that you check all of your ball joints before replacing all of them because the uppers don't go as fast as the lowers, at least not on my truck. How did you check all of them? I've learned to check them by getting under the car and trying to squeeze them with some 20" channel locks to see if the ***** are loose inside the sockets and by having someone turn the steering wheel rapidly from left to right as I watched for excessive place with a flashlight.
#1) That's what pickle forks are for
#2) There is now sway bar setup like that on the 2WD (the truck in question)
#3) 2WD ball joints are pressed in place (or in some cases, riveted at the factory)
