Tires with varying life left
Old Apr 22, 2008 | 11:47 AM
stumpgrinder's Avatar
stumpgrinder
Default Tires with varying life left
I am looking at getting some used BFG All Terrain TA's - 2 have 65% left, one has 50% and one has 40%. I figured I would put the two with 65% on the rear. Will there be any poor side effects of running tires with varying tread depth? Steering wise, or braking? I am getting them for the summer to save my Wilderness M/T for the winter, oh and they are cheap. Thanks!
Old Apr 22, 2008 | 02:05 PM
timsalas's Avatar
timsalas
Default RE: Tires with varying life left
heh Im getting new tires today, cant afford all 4 at the same time, so Im gettin two front new, and the rear are ok, Im hopin they be ok cuz itsd all I can afford right now lol.. then again im getting regular street tires since I dont go offroading
Old Apr 22, 2008 | 05:58 PM
WD OPN Throttle's Avatar
WD OPN Throttle
It may pull to the side. I would avoid BFG's thought. The AT/KO tires do not have good traction on pavement, especially in the rain.
Old Apr 22, 2008 | 06:26 PM
pcfixerpro's Avatar
pcfixerpro
Run the 65% tread's in the front, run the 50% on the right side rear, 40% on the left side rear. If you have an open differencial, you will wear down that 50% eventually on the right side and when the get equal, swap teh 65% to the back and then your 40% to the front. That's what I'd suggest at least. That is how I have mine set up right now at least. I'm just waiting for the right side to wear down to match the left now.
Old Apr 22, 2008 | 07:43 PM
rabbler's Avatar
rabbler
Running uneven tires is hard on the 4wd.
Be careful and watch out for excessive noise when in 4wd.
Old Apr 23, 2008 | 08:22 AM
stumpgrinder
Thanks for the info - I really appreciate it!
