Need Help - Truck Won't Start
Old Apr 22, 2008 | 01:36 PM
thylacinem's Avatar
thylacinem
Default Need Help - Truck Won't Start
I have a 1994 Dodge Ram. It drove fine yesterday, and when I came home, I parked it in the driveway. Today, it won't start. I've changed the coil, tested the spark plug wires, and still nothing. The wires and coil are not getting a spark. I've driven it for three years and every time, it would start right up. Now, with no warning signs at all, it won't start. It cranks, but it won't turn over. The battery is a good battery, and there is gas in the truck. What would cause it to do this?
Old Apr 22, 2008 | 01:55 PM
timsalas's Avatar
timsalas
Default RE: Need Help - Truck Won't Start
fuel pump?
Old Apr 22, 2008 | 11:39 PM
thylacinem's Avatar
thylacinem
Ok, so I've checked the engine codes, as well as some other forums, and it is starting to sound like it could be the crank or cam sensor. My question now is where are they located on the engine?
Old Apr 23, 2008 | 12:23 AM
dhvaughan's Avatar
dhvaughan
crank position sensor is on the back side of the block, passenger side, stuck down into the top of the bell housing. near the oil filter. hard to get to.
cam position sensor is inside (?) the distributor.
check all your fuses, including the main engine, IOD ? , etc.
