Have you checked the rear brakes to make sure that nothing is loose and dragging, because I had an 84 model dodge that made a squeeking noise and it turned out to be a clip came loose. Can you hear the squeeking noise if you jack up the rear end and turn the wheel by hand, or does it only do it when you are driving, it could be in a wheel bearing also.
