Quick question on hub replacement
Old Apr 28, 2008 | 11:23 AM
tomwom's Avatar
tomwom
Default Quick question on hub replacement
Can you replace the front hub on a 97 1500 4x4 without pulling the axle?
Thanks
Old Apr 28, 2008 | 12:07 PM
Baddnet's Avatar
Baddnet
Default RE: Quick question on hub replacement
Yes.. you still have to remove the axle nut ..but yea you can remove with out removing the axle.. but this is a good time to change axle u-joints... and sometimes the axles pull out with hubs...just becareful you dont cut the axle seal...when pullin
