Error Code Help.
My truck was stalling and i parked it now i fired it up and it seems to be fine only i keep getting the code P 0132 which is 1/1 O2S Shorted To Voltage. What does this mean and how can i go about fixing it ? Also is this the front or back sensor ?
Did you hook the A/F gauge to the actualsensor wires or to the vehicle side of the harness?
Best to do a visual inspection of the wires. If your concerned the gauge is causing problems disconnect it for a few days.
This code can also be caused by a bad o2 heater, which is integral to the sensor. It does require 12v to the sensor for the heater to operate so bad wiring can cause the code to set.
