Leaf Springs
Old May 1, 2008 | 09:56 PM
rwilhelms's Avatar
rwilhelms
Default Leaf Springs
I have a ram 1500 and my friend wants me to buy some leaf springs from his 2500. Will this work. Will it lift the rear of my truck or just be more heavy duty if it even does anything.
Old May 2, 2008 | 04:04 AM
Wrestling4x4's Avatar
Wrestling4x4
Default RE: Leaf Springs
use search.. 1500 is 2.5" 2500 is 3" believe u need a lil fabrication to mount it correctly.
Old May 2, 2008 | 12:25 PM
Crazy4x4RT's Avatar
Crazy4x4RT
They should work. I have a dakota and I put a rams 2500 springs under mine. What you might want to do is check to see if the leaf spring mounting locations are the same. If they are differnt than you can take the leaf spring packs apart and keep your top one and put all 2500 lower ones on. Thats exactly what I did.
Old May 2, 2008 | 05:06 PM
Trey318's Avatar
Trey318
Ye, i saw something like this on a show on Speed, where a guy put F-350 leafs on an F-250 for heavier loads on the rear end.
