Replaced front hub on my 97 1500 4x4
Old May 4, 2008 | 09:09 AM
tomwom's Avatar
tomwom
Default Replaced front hub on my 97 1500 4x4
I thought I had a bad u-joint on my 97 until I jacked up the front end. The passenger side wheel wobbled so much I thought it was going to come off in my hand! I knew instantly that the hub was shot, so I read some threads on here about replacing the hub and decided to try it. One of the things that helped me the most was someone posting this link: http://www.pavementsucks.com/tech/hub.php
I don't know if I was blessed or not, but it was really quite easy. The only difficult thing was finding a 1 11/16 socket, which I did at TSC for $12.50. The hub cost me $155.00 at Advanced and I also bought a u-joint for $15.00, I figured I'd replace that while I was doing it.
I would tell anyone who has some mechanical ability to go ahead, it's not as bad as you think!
One more thing, you'll probably need a long pipe to use with your 1 11/16 socket to get the axle nut off.
Old May 4, 2008 | 10:44 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Replaced front hub on my 97 1500 4x4
I might be doing this soon, so thanks for the info. How accurate was that write-up? Any other tips?
Old May 4, 2008 | 11:02 AM
padodgeram's Avatar
padodgeram
Yeah , you where blessed !!!! Is this a sure thing silver ?? never answered your orginal thread. heres a tip : juice , heat , impact ..
Old May 4, 2008 | 11:25 AM
Silver_Dodge
Don't know yet, haven't taken a closer look yet. I'm not in a huge hurry since i'm not driving the truck much.
Old May 4, 2008 | 11:38 AM
tomwom's Avatar
tomwom
ORIGINAL: Silver_Dodge
The write-up was very accurate, the only other "tips" I would offer is to use PB Nutbuster or Liquid Wrench on the axle nut and the 3 bolts. I also had my wife hold the brake on while I loosened the axle nut.
Old May 4, 2008 | 05:47 PM
Blaydrnnnr's Avatar
Blaydrnnnr
Mines getting done next month... I posted that link a few times here.. glad it helped... hope I get lucky like you did....good work!
Old May 4, 2008 | 06:27 PM
tomwom's Avatar
tomwom
ORIGINAL: Blaydrnnnr
I knew someone posted it, but I couldn't remember who, thanks!
